The Oracle Financial Services Lending and Leasing system includes archiving and retrieving feature that provides you with the capability to archive old data and store it in a different table.
The system batch process runs the purge / archive feature based on the system parameter setup. The system archives the following items:
The system purges the following items:
In the system, archiving is a two-way process:
You may set the “default days” for the archive feature by setting the following system parameters on the Administration screen. The parameters marked with _O are the items moved from O to OO tables. The other parameters are the items moved to O tables.
Parameter |
Default Days |
Description |
PAP_ARCHIVE_DAYS |
999 |
Purge Days for applications Level 1: PUR_APP_STATUS_CD is used to decide applications with what status are purged |
PAP_OARCHIVE_DAYS |
999 |
Purge Days for applications Level 2 |
PGL_ARCHIVE_DAYS |
999 |
Purge Days for GL Level 1: No of days after the GL txn was created |
PGL_OARCHIVE_DAYS |
999 |
Purge Days for GL Level 2 |
PJR_PURGE_DAYS |
999 |
Purge Days for Job Request Level 1: No of days after job request completion date |
POD_PURGE_DAYS |
999 |
Purge Days for Output Data Dump Level 1: No of days after process run date |
PPR_ARCHIVE_DAYS |
999 |
Purge Days for Producers Level 1: No of days after the Producer status is set to active and there exists no “Not Purged” account with this producer name. |
PPR_OARCHIVE_DAYS |
999 |
Purge Days for Producers Level 2: |
PPX_ARCHIVE_DAYS |
999 |
Purge Days for Producer Txns Level 1: No of days after the Producer txn was created |
PPX_OARCHIVE_DAYS |
999 |
Purge Days for Producer Txns Level 2: |
PUL_PURGE_DAYS |
999 |
Purge Days for User Logins Level 1: No of days after the Login End date |
PVA_ARCHIVE_DAYS |
999 |
Purge Days for Vendor Assignments Level 1: No of days after the Assignment Date and assignment Code in COMPLETED, VOID, CLOSE |
PVA_OARCHIVE_DAYS |
999 |
purge Days for Vendor Assignments Level 2: |
PVI_ARCHIVE_DAYS |
999 |
Purge Days for Vendor Invoice Level 1: No of days after the Assignment Date and assignment Code in VOID, CLOSE |
PVI_OARCHIVE_DAYS |
999 |
Purge Days for Vendor Invoice Level 2: |
You can retrieve archived applications using the Application Retrieve screen. You can retrieve only archived applications.
To retrieve an archived application
The system opens Application retrieval Search screen.
For more information about creating search criteria, see Searching for an Application chapter of this User Guide.
The system locates and displays all the applications that meet your search criteria on the Results screen.
Applications are sorted by priority and application number.
Field: |
View this: |
Company |
The company of the application. |
Branch |
The branch of the application. |
App# |
The application number. |
Date |
The date of the application. |
Title |
The title (applicant name) of the application. |
Product |
The product of the application. |
Status |
The status of the application. |
Sub Status |
The sub status of the application. |
Producer |
The producer of the application. |
The system loads the application in the Applications screen.
You are now ready to begin work on the application.
